The KiiÂs offer a completely full-range sound , with higher resolution, because of they way they ameliorate the effect of the room if you can hear more of what is on the recording that for me at least is an improvement .
Cables Âcan only affect the FR perhaps rolling off the treble slightly that is not an improvement just a difference.
Cables are audibly transparent unless the designer chooses not to make the so.
Compare your current and former cables unsighted.
Keith
If one set of cables rolls off the treble, as you say, and another set does not. Does this not constitute an improvement for the second set. I'll answer, no it does not. The reason, in simplistic terms is synergy/preference. If your system it too bright you may need cables to act as tone controls to reduce treble output. Conversely in a dull system you may need bright cables.
Which set is right, which set is wrong, neither they are just different. Add to this the preference for a bright or dull system. The permutations of equipment/cables are endless.
This is what I find appealing with the Kii's, it's a one stop closed system. However on the down side you can't tailor the sound, with for instance cables. You either like it's presentation or you don't. They may have a flat response across the audio band, but who says our ears are even across the audio band. I believe they are not.
What a great hobby this is.
Just to add I really do not need to carry out blind tests when comparing the LS-25's with the TQ Black's. The fundamentals are far superior with the former, I dislike the term night and day, but when the term fits.
