It isn't a small room:
Alex
yeh but your speakers are placed very close together and there is a lot of big furniture near by including a sofa and book case, its the space around the speakers that is most important
Alex
It isn't scientific. To be honest, going on my recollections, I'd say the Samson was quite a bit better than the entry level Naims I've had, which sound rather mid-rangey and very hissy.
The sonic signature of the Samson and the M130s is probably very similar indeed, because both are virtually transparent.
Do they all sound the same? Well, I think I can say that properly designed amps without any glaring technical shortcomings sound the same.
See, this is where it gets confusing, on the one hand you say that "properly designed amps without any glaring technical shortcomings sound the same", but then you say that "the Samson was quite a bit better than the entry level Naims I've had, which sound rather mid-rangey and very hissy" which implies that the Naim amps aren't properly designed.
Yet Serge and Robert say that Naim amps are properly designed and sound no different to Exposure or Quad or Meridian etc.
I agree, although certain obvious problems stick in the mind.The actual sound quality? No chance of remembering it with any confidence, IMO.
If it's several years since the Naim amps were heard, the excessive hiss levels may remain accurately in the memory. The actual sound quality? No chance of remembering it with any confidence, IMO.
Chris
But he is using different speakers now. So it could have been that his old speakers were more sensitive and therefore hiss from the Naim amp could be heard.
I don't know (I've never used Naim amps, or Samson for that matter).
I contend that Naim amps, when used as the manufacturers intended will sound the same as a Quad amplifier under the same conditions. In the case of the Naim amplifier, this requires a length of high(ish) inductance cable as the amplifier is not unconditionally stable. The Quad doesn't care, so it can happily use the Naim cable.
This issue of unconditional stability is the reason I won't buy a Naim amplifier. Sonically, I have no issue with them at all, nor with build quality. I just find it a y perverse design decision not too make the amplifier unconditionally stable when most manufacturers manage this perfectly well. The cycnic might think it's so a Naim dealer can sell their fairly expensive 'speaker cable whilst the Quad user can quite happily use lighting flex.
S.
Nope, NAC A5 at first, then Avondale Black Link. Incidentally, Les Avondale's cable seemed to work much better with the NAP150. With his own amps, it didn't seem to make much difference if any, and I eventually changed to mains cable - which if anything suited the M130s better.So maybe that's the reason, hammeredklavier wasn't using Naim cable with his Naim amps.
All amps measuring exactly the same in every parameter, used under exact same conditions at exactly the same level will sound exactly the same.The exactly and parameterbit is where it all comes apart.
They don't have to measure the same, just both be good enough such that both are transparent. If one amplifier has 0.05% distortion and the other 0.001%, the first is 50x worse, yet won't sound any different. If one amplifier is 0.5dB down at 20kHz and the other is 0.5dB down at 100kHz, again no audible difference. If one amplifier is 100 watts, and the other 1000 watts, no difference if both amplifiers are level matched and the smaller amplifier not allowed to clip.
And so on. Identical measurements are not required for identical sound.
S.
How do you measure transparent?
That bloody cable's £20/m...!The cycnic might think it's so a Naim dealer can sell their fairly expensive 'speaker cable
what are the test you are referring too?Y
Over the years a body of experience exists which through testing has continued to confirm these thresholds.
S.
You don't. Transparency is achieved when an amplifier or other device passes a straight-wire bypass test.. This has allowed the threshold of audibility to be derived for parameters like distortion, frequency response variations, noise levels, etc etc.
The beauty of the straight-wire bypass test is that it can be applied at any time, and the transparency or otherwise established.
However, it has to be appreciated that thresholds of audibility are statistical in nature. It is quite possible that somebody somewhere can hear 0.001% distortion, or a 0.1dB variaton in frequency response at 10kHz. Possible, but pretty unlikely.
Considering that all hearing is a continuum between those totally deaf and someone who can hear a mouse fart at 100m, it surprises me somwehat that there are many on here that put themselves at the mouse fart end of the hearing ability continuum.
S.
