However, to compensate somewhat comes greater experience and descrimination, so older engineers know what to listen for
Nothing? Why do they need to listen for anything? I thought they just looked at a graph to see all was well?
Sorry to keep harking back to Peter Walker, but in an interview with Ken Kessler reported in KK's book on Quad, PW said they never listened to music as part of the design process only test tones and other "funny noises" and then for audibility of certain effects.
When I was designing Broadcast Audio equipment, I would have been laughed out of the AES if I'd designed "by ear". By all means listen to the finished result as a sort of reality check or final "well done" to oneself, but as to listening to capacitors, (or even solder...) no.
S.
Well, I no longer have the Naims, so it would be wrong of me to say that. I can, however, say that any difference would be very small.Don't you mean 'they both sound the same'?
Just wondering how many of you it all sounds the same guys are over 60 and how do you think your hearing compares to a 20 year old.
So they are different thenWell, I no longer have the Naims, so it would be wrong of me to say that. I can, however, say that any difference would be very small.
I can't be sure, I don't have the Naims any more so I can't compare them side by side. As I say, if there is any difference then it's small.So they are different then
By distorting it, for starters. Or by making some bits of it louder than they should be, relative to the other bits.In what ways can an amp significantly infleunce the sound ...
The Naims certainly did some hissing, and the Samson doesn't. Soundwise, I think the Samson is quite a bit better than the Nait and at least as good as the the NAP150/NAP90/Flatcap2 combo. Now, bear in mind that in my current set up, there is no superfluous pre-amp between the DAC and the power amp, which is going to stack the odds in the 120a's favour - all other things being equal.Hang on, just a minute ago you said they were 'quite a bit' better and the Naim was 'very' hissy, relativly speaking I assume.
Now any difference is very small? Sorry dude, the credibility of your opinion just left on a bus.
The difference, of course is that there is a large body of evidence from all sorts of fields showing that sighted evaluation of anything is fundamentally unreliable.
I mean exactly what you just said.So where does 'very small' enter into it? If al amps sound the same why didn't the Nait and bigger Naim amps sound the same? For what it's worth, I think that he Nait and bigger Naim amps do sound very, very similar if not stressed.
This test is flawed in two ways.You will need a pre-amp with two identical outputs, the Power Amp under Test, an attenuator, an A-B switchbox, a dummy load and another power amp and 'speakers.
You arrange the output of the pre-amp to go to both the PAuT and switchbox, the output of the switchbox goes to the power amp and 'speakers.
The second input of the switchbox goes to the output of the PAuT feeding the dummy load, through the attenuator such that the A and B parts of the switchbox receive the same signal level, matched to 0.1dB.
Then listen to some music direct, i.e. the A path and switch to the B path in which the signal goes through the PAuT. If this is done blind, and one can't tell whether the switch is direct or going through the PAuT, then the PAuT must be transparent. The dummy load can be a simple resistor, or it can be a complex load to simulate a difficult loudspeaker, or indeed it could be a difficult loudspeaker if that is placed in a separate room such that the noise doesn't affect what is being heard in the listening room.
If when switching A-B on a wide variety of music it can't be identified which is direct and which is through the amplifier, then the PAuT must be transparent.
This test can of course be done with any component.
Quad famously did it by daisy-chaining 50 of their Quad 303s and apart from a bit more noise, which wasn't audible under the music, they were still transparent.
Indeed, and I suspect a lot of hi-fi amps aren't.Secondly, you are comparing one amplifier against another, which assumes the baseline amplifier is reliably transparent under the test conditions.
Firstly, it relies on subjective listening. If you can't tell the difference, it doesn't mean someone else can't.
I was half expecting a 'scope and some spectral analysis to be part of this transparency test, but I guess I'm heartened that even you rely on your ears to ascertain transparency.
