Rockmeister
Ah ok got that. Thanks. !
Some good info from testing here. Tldr, round is good and flared both end. Worth a read though
https://drive.google.com/file/d/1SU56ScKuPIr7SftWRHB7eeKdjmnnMh3b/view
Is there a tl;dr version of this?
- If the modelling shows a flat response to Fb, and Fb happens to coincide with an axial room mode, will this cause a greater in-room response peak than if the axial mode were at a higher frequency than Fb?
- Does port location influence this, i.e. how close the port is to the room boundaries compared to the driver? Is this why rear-ported speakers cause issues when placed too near the front wall?
I have a question on port tuning:
This is my thinking too.I can't see why it would, but it is very easy to get the port tuning wrong and end up with a peak at Fb (Especially with smaller speakers where a slight increase in size can make quite a difference).
I'm (perhaps wrongly) thinking of the port as a narrow band speaker driver, so my logic is that the further the port is located away from the driver, the more difference in the extent to which it excites room modes. E.g. in a sealed enclosure, the closer the speaker driver is to the floor the stronger the room height axial mode will be excited, the closer the speaker driver is to the front wall the stronger the room length axial mode will be, etc.I've seen this talked about on diy speaker building forums that I use, and according to the threads I've read it shouldn't make any difference as long as the port is not too close to the wall as to affect the tuning frequency, BUT I've seen a lot of people on pinkfish complain about boomy bass with rear ported speakers. Without making an identical set of speakers, but with the port on the front, It's impossible to know. Maybe the people that complain of boomy bass are just placing them too close to the rear wall? Typical port tuning frequencies are omnidirectional so in theory it shouldn't matter.
Presumably the magnitude of the dip in the 'ultra nearfield' frequency response measurement of the driver at Fb remains the same regardless of where the port is located, as long as it isn't obstructed?
why so? Would I better swap my port to be 1/3 down from the driver rather than I/3rd up from the bottom of the cab?It's not something I've looked in to because I always place my ports very close to the driver.
Assuming port location does indeed affect excitation of room modes, which has not yet been confirmed, then unless your ceiling height is 6 metres (thus producing an axial height mode that coincides with your 28Hz port tuning), I don't think it will make any difference in your case.Would I better swap my port to be 1/3 down from the driver rather than I/3rd up from the bottom of the cab?
My ceiling probably IS around 6m...It's an open stairwell room with double height up to the sloping roof, so!?
I think I'm just going to run away now, build the damned things and say, 'they are perfect' regardless...all this mode stuff and 18.724 cm ports needing tuning to a possible 17.41 after downloading room resonance tones for measuring.
HELP!
Using the REW Simulator to model the effect position has on room mode excitation, and again assuming that port location affects room modes in the same way as driver location, then moving the port a few inches closer to the driver makes naff all difference to the size of the peak at 28Hz (we're talking tenths of a dB which is basically inaudible). It does appear to affect the 28Hz multiples more significantly (56Hz, 84Hz, 112Hz, 140Hz, 168Hz, etc). However, a lot of this will also depend on the other dimensions of your room and how these multiples coincide with the 28Hz multiples, and also the position of your speakers and listening seat relative to the room's other boundaries. Too complex to explain in writing, you'd be best to download REW and play about with the simulator yourself to see what I'm talking about. We are getting into OCD territory here though so I'd probably be inclined to stick with your original plan otherwise you'll never get started!My ceiling probably IS around 6m...It's an open stairwell room with double height up to the sloping roof, so!?
HELP!
I'm not even going to attempt to model that!
