Rockmeister
Don't start!
I think @cooky1257 was implying that Tannoys are a good choice for this.Don't start!
Still I am serious considering porting the speakers at the sides...outward facing and higher. I ain't over till it's over
Yes.Have been following with interest because I have some HPD 315s to house. Will the info here be applicable to my drivers?
If cooky says yes, then it's yes. I'd put no . The later HPD's have a different set of specs to the MG's and so cabinet dimensions, crossovers and porting will all vary a little. The basics of timber, framing, bracing and damping might all apply in general terms.Have been following with interest because I have some HPD 315s to house. Will the info here be applicable to my drivers?
Closest I could get was 120L, 2 ports 100Dx 170L tuning to 40hz, with a very Garner like bass shelf and resonance peak for the MGHE that is almost identical to a 49hz tuning , block one port for MG12R.Is it crazy or genius for me to be considering designing a 120L enclosure for the MG12 with two ports, one tuned to 28Hz and the other tuned to 49Hz, to provide the choice to install either the MG12R or MG12HE? i.e. I'd simply block off one of the ports with closed-cell foam? (or socks?!) depending on which driver I install.
Are there any downsides to this, other than the 120L volume being more optimal for the MG12R than the MG12HE?
I'm curious if there would be any difference in how a closure with a single port performs vs an enclosure with two ports but one of them blocked off? I'd imagine there would be a difference since a port blocked with foam/socks is not a reflective surface like a 1" thick cabinet wall, but would the difference be enough to be audible?
Sorry Frank, I'm not sure I follow (I'm still on a steep learning curve!). If 120L Fb for the MG12HE is 40Hz with 2 ports 100Dx170L each, what will 120L Fb for the MG12R be with one of the two ports blocked off?Closest I could get was 120L, 2 ports 100Dx 170L tuning to 40hz, with a very Garner like bass shelf and resonance peak for the MGHE that is almost identical to a 49hz tuning , block one port for MG12R.
1 100mm dia port @170mm long tunes 120L box to 28hz, 2 ports 100mm dia@170mm tunes it to 40hz. ie one port open suits the 12R, 2 open suits the 12HE. Arden 3 ports with different box tunings depending how many are open.Sorry Frank, I'm not sure I follow (I'm still on a steep learning curve!). If 120L Fb for the MG12HE is 40Hz with 2 ports 100Dx170L each, what will 120L Fb for the MG12R be with one of the two ports blocked off?
Are you suggesting two ports tuned to 40Hz instead of one tuned to 28Hz and the other tuned to 49Hz because 40Hz is more optimal for the MG12HE in 120L enclosure or because it's pointless having two ports tuned to different frequencies since one will always need to be blocked off? Is this why the three ports in the Legacy Arden are all the same size?
In the Arden, does Fb increase or decrease as you block off the port/s?1 100mm dia port @170mm long tunes 120L box to 28hz, 2 ports 100mm dia@170mm tunes it to 40hz. ie one port open suits the 12R, 2 open suits the 12HE. Arden 3 ports with different box tunings depending how many are open.
