martin clark
pinko bodger
Obviously.
Should be fun to solder to a ‘nana plug!I’ve just rescued twenty odd metres of 25mm2 tri rated cable from the skip at work. Top quality German cable so I think this stuff will be just the ticket to make some decent speaker cables![]()
You keep believing me old mate....the world needs believers.They're good value cables as they're sold direct, and based on everything i've gathered, punch well above their price point in sound. So antithesis to this thread topic.
flagship Lessloss cables
I have some 1m long 70mm2 coroplast HV cable off cuts, it’s basically a co-ax with a 70mm2 core of fine stranded copper and a foil and copper braid screen. I just need some decent phono plugs that will take a 19mm dia cable. They would make lovely low loss interconnects, bend radius is 8d so I may need to put stuff further apart!
Don’t worry, I was squarely taking the P!!! Not sure on the strand count, but I’d be tempted to crimp a connector to cable that size. Poke a z-plug into the copper and crimp a tube splice over the whole lot with a decent crimper, you basically cold weld the lot together and tidy up with heat shrink.Apologies Puggie, phono plugs are a different ball game![]()
Try some of the World’s Best cable range. Very well built and sound good for reasonable outlay.
People are mugs.
Why do decent audio cables cost so much?
With the exception of cables laid decades ago that haven't outlived their useful lives, ALL undersea cables are fibre optic.
Yep. Visually impressive, well built and not expensive. As expected, they sound no different to any other well constructed cable.
I do to struggle comprehend how ‘seasoned’ audiophiles do not realise this.
Anything other than:
"Audiophiles are fecking idiots"
Is the wrong answer.
I assume these cables are directional……Go Big or go Home !
My god, I've never seen a breeding pair of cybermats in the wild.My suggestion for your typo.
