In my experience, which is not much. I found out it was the inrush current into cap from zero volts, the first part of the curve is sharp so on the M110,s WB, M50 and the new M40A? they are all pre charged to about 0.1 or 10% of there working voltage, also noted the caps with low ESR draw more current on start up and after a few failures, discovered the ultra sonic aluminium welds were damaged to the terminal, this reduced there current operation and increased the current into those remaining welded. So the failure got worse until nothing of use, this also cause small hot spots and destroyed the dielectric chemical, this caused leaks, so bye bye cap. Now what I have found with soft pre-charge is the cap last up to 10,000Hrs longer, and this was with a 50V PSU at 100Amps.
Next I tried it o SMPS i.e. soft start extreme, life went on for those as well.
Conclusion:- On all the time not good as they heat up life is shortened, switch on with massive inrush, not good. Pre-charge better so I go for pre-charge if possible followed by soft start, as we do, or use crap diode with a Vf of 2V plus or so he he.
Have fun guys.
Just to change the subject I had my first day out this week in over a year .well out side a pub with my step son, it was great after being locked in for a year.
The Redheaded waitress was good but the IPA and grub was amazing.
The Barge Inn.
