It is official feature, I once opened it. There was plate for different voltages, but no markings which is which. But if it worth doing, will find out how it is needed to be done. Thanks.
Curious why you say tube rectifiers are silly? Seems solid state ones are a less than ideal alternative. I run various, including 6860WA and 6550s, and have not had an issue with them.
It doesn't have to be complicated. As Tony says you are just connecting it to a different part of the transformer and engaging fewer coils.Found a picture which I took when opened amp. Looks that Photobucket wants money for sharing photo on forums.
There was markings on that voltage plate. Is it enought just to move that single wire from 220v place to 230v place or something else must be done? I cannot see other side of plate without removing it, it feels for me too simple.
I used to have a pair of 2nd audio innovations triode amps ,some years ago ,they had solid state rectification, I then fitted a pair of Border Patrol valve rectified psu's, the improvement was dramatic!
Much more composed and dynamic, before when the music became more challenging and complex ,the amplifier seemed to lose control and become congested .
Apparently the critical difference was the use of a choke input filter which is unique to Border Patrol as most manufacturers use choke smoothing with capacitor input filter .
Jez, no the critical difference is the choke input filter configuration, this is what makes the improvement, as I said .
No, it's not.
Oh yes it is lol
I know what I heard and was nowt to do with caps or grounding .
One good thing about valve amps is when they fail they only tend to harm themseves. When solid state amps fail the badly designed ones without proper speaker protection can send DC through your valuable speaker destroys the voice coils and crossover, in some cases of some really bad ones even setting the speakers alight! No valve amp can do that as the output transformer blocks DC. The amp may blow itself up, but it is harmless to the surrounding components as long as it doesn’t actually catch fire!
Can be any amp that lacks a transformer output, or capacitor output, so most SS designs. If a tranny goes short then you can get supply rail voltage DC delivered direct to the output. If it has a DC blocker, no problem, if not then you can blow speakers. Some speakers have a cap blocker, FWIW, but there is a sonic impact.In all my years on hi-fi forums, I have never heard of such a thing happening to someone’s loudspeakers. What are these badly designed amplifiers you speak of?
