I’m glad the Russians can still be trusted with something.
Ah, but the USSR-era valves are far more highly regarded than the current Putin-era tubes!
PS No difference anywhere else really, the best valves were made back when they were a standard device.
I would put the best USSR 70's and 80's era Russian valves up there with Brimar, Mullard etc. Even they are getting rarer now though and fakes can be seen.... "OTK" markings added to non mil approved valves etc.
I have what I am 99% sure is a NOS set of 1964 yellow-print Mullard EL84s and I actually prefer the 6P14P-ER I linked to upthread! The same doesn’t go for the small signal ECCxx tubes though, 1950s-70s GB, EU or US manufacture valves sound nicer to my ears, and as for GZ34s etc nothing matches a Mullard.
PS By saying that certain early Tesla ECC83s are stunningly good, up there with my favourites and no one should ever confuse them with the current JJ versions.
followed by rectifier valves on vintage amps or those modern amps silly enough to use them
Even in this case it can be done. I bought a Chinese EL34 amp, second hand and cheap, and used it for 5 years. The power supply transformer eventually went down because it was designed for 220V primary and running it on 240V UK meant that it ran hot, cooked everything and eventually died. No manufacturer original was available and even if it had been it would have been 220V primary so no better. I got my repairer to spec a replacement trafo and had it made by Demeter Transformers of Chelmsford for £90, posted. 5 years further on again it's as sound as a pound.The only time that yes, "only the manufacturer can fix it" is true is in those small number of cases where a part specific to that manufacturer is needed and they won't sell the part to an independent repairer. In a typical valve power amp this would mean only the output transformer and maybe the mains transformer. All other parts are generic generally.
Curious why you say tube rectifiers are silly? Seems solid state ones are a less than ideal alternative. I run various, including 6860WA and 6550s, and have not had an issue with them.
If we speaking about valve amp reliability in what trouble I can get to run 220v spec amp into 230v supply. It is not 240v but transformer is quite hot. Can just 10v make any difference?
Where are you based? If in the UK our voltage is stated as “230” to match with some EU regulation, but has a hefty +/- percentage with more on the + side. If I measure mine it is frequently around the 240-244V level. That will very likeky cook a typical 220V Chinese tube amp.
Not UK, I measured voltage several times at home, it is 230v. Amplifier is Unison Research S6 mk2. Theoretical I could it open up and wire it to 230v, but there is no easy access and I am not sure if it is worth to go for that trouble to change it.
If the amp has a 230V tap it is well worth using, your valves and capacitors etc will have a longer service life. Assuming it is an official feature I’d certainly do it.
