adamdea
You are not a sound quality evaluation device
Hi Gustav,You are over-fitting the analogy. My point was simply that if you want to identify the effects that a cable might have on noise, as Amir explicitly stated in his concluding remarks of the Nordost cable, you don't use a DAC that is known to effectively reject noise. Just as if you are testing the effectiveness of an antibiotic and you performed the tests on a known antibiotic-resistant strain, you would be rejected by the editors without even being sent out for peer review. The analogy is in the big picture, not drawing direct comparisons between the antibiotic and the cable and the bacterium and the DAC. FWIW, you originally quoted a repeat of the analogy, which I originally made much earlier in the thread with more explanation but I can't be bothered to find it to link it directly.
Edit for clarity: the overall point is that the ASR review of the Nordost USB cable is a waste of the server resources that it takes to store and serve it over the internet because it is 100% uninformative.
If the problem is noise in the DAC, and someone's DAC is indeed susceptible to this and they have their own reasons for not wanting to switch DACs, then they are free to explore and discuss whatever ways to treat it that they want, even if that includes expensive cables. Who am I to judge, with my £200 Cambridge Audio DAC and £6 USB cable?
I don't think we are a million miles apart, and I can see why you say I am over-fitting the analogy, but what I am tryign to do is to make a slightly different pooint using it. The point is that this idea -that what usb cables are for is to ameliorate (in a roudabout way) the suscpetibility of certin dacs to noise- is an ex post facto one. What the cable manufactuers (and reviewers) generally claim is to make the sound better in general terms (see the wireworld blurb) and in ways and using materials which do not appeaer to have been specfied for this purpose. They don't say, that their cables are not going to work with dacs which are not susceptible to ground noise loops (and not just becasue they don;t say their cables are there to do that job). The only reason for alighting on the noise idea is that some minor effects have been thrown up by certain measurements (once again showing how measurements show up the inaudible). It's a convenient measurable effect which we can pretend must be the reason for all of this.See jitter (effects of inaudible levels of as "explanation" for doubful reports).
It's a free country and if soemone wants to mess around with usb cables on the basis that they might have a noise problem which they solved, then this would be fine. But
-it still wouldn't make any sense as there would be better ways to skin the cat if there actually were a cat and it actually needed skinning.
-it isn't really why one would buy a usb cable of this sort in practice, it's just an apologist ex-post facto rationalisation and does not match the alleged benefits claimed or reported.
Finally- when dealing with the realy expensive end of the usb cable spectrum it really doesn't make any sense to be paying vast sums to address issues (even in a dumb way) which should not arise in any dacs with which such expenditure for the cable would be anything like commensurate.
