Anyone know what the best way is to remove rain X from a screen?
A good squirt of Fairy liquid, then a gentle wipe round with a wet cloth. Then rinse the cloth in warm water, go again. Keep going until the Fairy has gone. DO NOT use anything abrasive, especially not a green nylon pad.Anyone know what the best way is to remove rain X from a screen?
Vinegar isn't the answer because Rain X is oil based and you need a surfactant. Vinegar isn't this. It's an acid, great for removing limescale but not oils and greases.
Yes, not cleaning can damage paint work, depending on just what lands on the paintwork.A colleague once asked, "do you think that not cleaning my car will damage the paint work?"
He had a company car and so had no finance risk at stake, just his conscience.
We never did establish a likely outcome!
That's how wheel cleaner works. Brake dust contains iron dust that is worn off the cast iron brake discs in normal use, it then sticks to the wheels and oxidises. Wheel cleaner has chemicals that turn it into the purple solution that can be washed off.Yes, not cleaning can damage paint work, depending on just what lands on the paintwork.
Both bird lime and iron fallout can very easily totally embed itself through the paint or clear coat, and permanently mar the paint.
This may not become apparent for months, but by then, way too late.
This is our van that had not been touched for months, and someone had been grinding a car wing close to us.
Rather peeved when we saw black dots appearing everywhere.
The entire van was like this, worse still on the bonnet.
The liquid goes on clear, and turns plum when in contact with iron/ferrous materials as it dissolves them.
those black dots would have turned to pure rust and have been permanently embedded had we not caught in time.
Why not?
Those black dots would have turned to pure rust and have been permanently embedded had we not caught in time.
Care to guess what brake disc fallout looks like?
That gets pretty much everywhere as well, and not just from your brakes.
Then we have the fun of tar spots, which we all get when re-surfacing time comes around.
It will scratch the glass.
You would think it would be fine, but it will scratch a screen. My dad did this back when I was a kid, he was trying to remove flies. He did, but scratched the screen and used to curse it in bright sunlight for years afterwards.How? Nylon is softer than glass, I've cleaned a screen with wire wool before.
not sure about that. AIUI the outer surfaces (both sides) are glass, it's the inner (middle) layer that's softer material. I think polycarbonate. This is why a stone chips the outer layer but the middle layer remains intact.Car glass isn't just glass... It's laminated also and its this that will scratch...
