Yes there is, actually. "Excessive acceleration" will get you a ticket if observed by Plod, a friend of mine has the fine and points to prove it. In a built up area, driving a Triumph GT6 sometime in the 90s. He gave it a squirt between 2 sets of lights that are only 50 yards apart or so, didn't exceed 30, didn't leave 1st gear I don't think, ticket.
I stand corrected vLooks like this maybe the catch-all as opposed to a specific offender in itself.
<<Driving without Reasonable Consideration
The offence of driving without reasonable consideration under section 3 of the RTA 1988 is committed only when other persons are inconvenienced by the manner of the defendants driving, see section 3ZA(4) RTA 1988.
The maximum penalty is a level 5 fine. The court must also either endorse the drivers licence with between 3 and 9 penalty points (unless there are "special reasons" not to do so), or impose disqualification for a fixed period and/or until a driving test has been passed. The penalty is the same as for driving without due care and attention.
A driving without due consideration charge is more appropriate where the inconvenience is aimed at and suffered by other road users.
Note the essential difference between the two offences under section 3 of the RTA 1988 is that in cases of careless driving the prosecution need not show that any other person was inconvenienced. In cases of inconsiderate driving, there must be evidence that some other user of the road or public place was actually inconvenienced; Dilks v Bowman-Shaw [1981] RTR 4 DC
This offence is appropriate when the driving amounts to a clear act of incompetence, selfishness, impatience or aggressiveness in addition to some other inconvenience to road users. The following examples are typical of actions likely to be regarded as inconsiderate driving:
flashing of lights to force other drivers in front to give way;
misuse of any lane (including cycling lanes) to avoid queuing or gain some other advantage over other drivers;
unnecessarily remaining in an overtaking lane;
unnecessarily slow driving or braking without good cause;
driving with un-dipped headlights which dazzle oncoming drivers, cyclists or pedestrians;
driving through a puddle causing pedestrians to be splashed;
driving a bus in such a way as to alarm passengers.
Prosecutors must decide which version of the offence to charge as the section creates two separate offences and there is no alternative verdict provision in the magistrates/youth court: R v Surrey Justices, ex parte Witherick [1932] 1 K.B. 340.
CPS website. >>
Although the PH folk can’t agree on that:
https://www.pistonheads.com/gassing/topic.asp?h=0&f=10&t=1524911
