That's forward thinking !I'd assert that the people should be reverting back
It'll transform your life.I'm moving closer to the substation.
I think a much more audible difference will be noted between suppliers using different nuclear, coal or renewables.As it is an accepted fact that the source should be put first in hifi systems of any quality, I was wondering if anyone had experience of changing electricity suppliers, say from E.ON to NPower. Or, if you are into streaming, is it better to change internet provider first?
I don't see how any comparison can really be valid if you don't take the basic step of having your own dedicated utility pole installed.
You've just reminded me - an old mate of mine had a three phase supply installed in his front room to power a big Krell amp. I never understood the logic, assuming there was any?I know someone who had a dedicated 3-phase supply installed to his purpose built, detached, listening-building.
It truly is an unspoofable hobby...
Russ Andrews used to, and maybe still does, sell their twisted version for hifi mains installations. It may well be the same stuff as in their leads. I was slightly tempted 2 decades ago then saw the price and how much I'd need. Good ol' T & E is fine; 4, 6 or 10mm2 depending on requirements (2.5 mm2 much too thin for radials i.m.o., though this is what I used in the eighties and again in the nineties.Is anyone marketing audiophile mains cable? If not that’s a prime opportunity right there.
Joking, yes? Unless you live in a filing cabinet or computer storage.Being a audio file
