Any power cable has some stray capacitance. No power cable has the sort of capacitance quantity so that it can reliably and consistency provide useful filtering action. For the latter you need a real filter (and even then!!!!), and once you add such a filter the cable is no longer a 'cable'.
Rhetorical question to all: what does the mains wiring in a typical home look like, when observing it from a single wall socket and from DC to light?
I like this explanation from candycable on whathifi
post 5
http://www.whathifi.com/forum/accessories/mains-cable-confusion
"Contrary to popular belief, the
main benefit of screened mains cables is the fact that it creates a high
capacitive link between the live, neutral and earth- i.e. a nice filter. This
filter effect way outweighs any airborne RF disturbance effects- in fact
airborne RF pales into insignificance unless you live under the transmitters
and crystal palace. However, steel braid mains cables do just as most filters
do, and dump the junk picked up straight back on the earth. Unless you have a
technical ground and a 'dirty' ground. In some situations we even have a safety
ground separated out to prevent chassis being charged with noise from the dirty
earth. My favourite is the Studio
Connections cable which is, like military cables, uses a conductive plastic
shield that has a resistance to it and a filtering effect. This means it work
as a filter, but the resistive properties dissipate the energy as heat. It
works. That's why we use it when design marine cables that have to be immune to
RADAR- the RADAR energy simply disappears leaving on trace.
If you listen on a good, wide band system - say a Moon/Focal, to decent
interconnect and speaker cables (from a physics point of view a rarity by the
way) and most hyped up cables, the difference really is staggering. If its not
then something ain't right, or its already at the top pf the game. Until you
have heard the difference, I would say, you have not heard a true system with
decent cable. When you think the performer is the room, that when you know you
are close to the music. Mains cable makes less difference, but once the components,
interconnect and speaker cables are well selected, then a good mains cable will
bring the image in a little more well grounded (excuse the pun) - why - because
another level of noise has been removed- the horizon is more stable.
People say listening is subjective, but our listening is intuitive and
evolved over millions of years to work to understand where noises in nature are
coming from- the ears listen to a few kilohertz, but the brain measures timing
differences of the sound hitting the ear drums to much smaller times- in the
realms of 250 KHz- (that explains how we sense Jitter that resides way out of
the traditional audio band). When everything has the right phase timing and
nothing is delayed by the cable (propagation delay is the technical way we
refer to 'cable speed' and is core to the performance of a system) - when
everything is right, it feels right and the body relaxes. Go outside, close you
eyes and listen to a bird call, you can point to the birds position to within a
few degrees. Everything is in place and that's a lot of timing info being
processed fot that to happen. If the components of the bird call are delayed
and messed around, you would not feel comfortable and could not position it so
well. Its our natural defence, fight or flight skills at work."
Think this is the cable he mentions
http://www.studioconnections.co.uk/Power.htm
you can buy 100m of it if you want to kit out a house or studio.
