Still waiting for a local call re: M7 Cap screws....
Wanting to move on, and considering the Kaputski nature of the driver in question, I took a blade to the cone, and
nostromo ... this one's for you
With cone removed....here's one I prepared earlier, and in best 'Blue Peter' fashion.
Conveniently found a cast iron 3" G clamp, and fighting against the speaker magnet, arranged the tip just under the speaker frame.
I needed to remove with a stanley blade, the old clear silicon that Linn had lovingley applied all those years ago, as it was preventing the clamp from 'seating'.
With a couple of old jenga pieces (other blocks will suffice) and a stout bit of softwood, arrange a bridge that'll allow the casing to emerge from the baffle.
Carefully align clamp vertically....and slowly tighten. When it was 'right'....this clamp parted from the magnet as force was applied to the speaker casing.
A few turns, and you'll hear the silicon tearing, and see the edge lift from the face of the baffle.
Gently does it...touchy-feely....
a little bit at a time, and moving edge to edge.
After half a dozen or so movements.....it was free enough me to lift clear.
And .....Hey Presto (haven't heard that for a while)....one mid-driver removed, and no chisel/scredriver damage from enthusiastically administered levering!
Of course....if the drive you're removing isn't shot like mine....then I'm sure the M7 cap screw method would be the way to go
