Has anyone with a project machine ever emptied the catch tank? I use it so rarely that it never manages to build up, I guess it just evaporates away.
I think some of the Loricraft machines are supposed to be reasonably quiet.
I have, and it is amazing how much black gunk is hoovered up, Once cleaned I flush through with tap water.
Furthermore, I should add that if you do not empty it is will start getting heavy, but it does depend on the number of records you clean, I would say every 500 records cleaned it would need draining.
I can understand it if you're doing loads in one go, but I only do them when I buy them, two maybe three at a push. Then it sits idle, and I presume it dries up as we aren't talking about gallons of liquid here.
A couple of record retailers have advised me to try wet playing vinyl as the very best way of clearing all crap out of the grooves of old vinyl. Anyone here tried this?
