Radfordman
Perhaps go for a 303 instead. Good old workhorse.
I've considered it but does it have enough grunt to drive ESLs?
If it's ESL57's or ESL53's then the answer for me in a fairly large room is yes. I have two pairs ESL57, one set ESL63, Quad 303 Quad 405-2 and Quad II's (and a lot more)
Not only that but
(a) the 303 is incapable of damaging the ESLs (max 33V voltage swing, and regulated to keep it that way) and
(b) the 303 laughs in the face of capacitive loads & doesn't mind the odd short circuit on its outputs
Compare and contrast the Quad approach of designing an amplifier which will drive the same company's speakers flat out all day with Naim's 250, which won't drive the Ovator speakers (albeit at ear warping levels) without shutting down.
Well done boys, brilliant design there. An amplifier from near the top of your range won't drive a pair of speakers from near the top of your range. I'd never have thought f anyone putting those together after all. Superb thinking.
Well I've shipped the 405-2 back to the seller, so I may think again. Either a 306 / 606 or another 405-2. Many variables to consider. Meanwhile I have a PhD thesis to defend and a wedding to organise so this may have to take a bit of a back seat for a while (unless I spot a bargain of course).
A badly set-up 303 sound just about acceptable (depending on ones standards) and a well set up one, to me is better than a 405-2.
Sorry, for some reason in my mind I thought that you had Tannoy DC's, still the above is true.
I have, 15" Monitor Golds! I have two systems, the Klipsch Heresys are in the other room.
Tony.
On the wider debate, the only older Quad that I wouldn't recommend is the 707, which just doesn't have the "house sound" somehow.
Pete
I wonder if there'd be some synergy between a carefully fettled NAC 32.5 with a DIY-cap into a 303 or 405?
