Robert
Tapehead
Those look right for the stock 306.
However I'm going to be a heretic and suggest that you use Panasonic 6800uf parts.
The 306 is tiny and was an 80s design. Caps have shrunk and got better since then and while we cannot be certain, I'd bet money on the original cap value being used because they simply couldn't get anything larger in the case.
It also gets hot in a 306 so there should be some benefit from the higher temp rating of the panasonic part in terms of working life.
I use these in mine and in the few I've serviced for folk:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=339-7060
