A tweaked up 303 *might* be better, but hang on. Set the clock back to 1978ish. Quad's flagship speaker at that time is the 57. Most owners run the 303 with them. Then Quad launch the new all singing and dancing power amp, design award etc. Does anyone *really* thinbk it's going to be worse than the 303 on the same manufacturer's flagship speakers?
If the OP is near London and wants to try/borrow a servicecd 405/2 I'm happy to help.
I'm also happy to service a 405 with fresh caps on the boards and PSU for the cost of parts.
There are certainly important spec differences between the II, 303 and 405 and while I think these would give a minimal difference into a high impedance load, they should be audible into many modern low impedance speakers.
Back in the old days where 16 ohm loads were common and designs rarely fell below 8 I can see why the distortion spec alone would largely determine quality.
When driving difficult loads there are more factors to consider such as the stiffness of the PSU and output impedance and these become more important.
So I think Quad were right in their claims - for the period.
The big question would be can someone tell the difference betwwen say a Quad 606, Naim NAP250 and say a Cyrus power amp today. That gets interesting as I'd put good money on listeners being unable to reliably tell them appart unsighted. If the 405/2 wasn't clipping I'd add that to the list.
It must surely all boil down to audibility and importance.
If you have to sit and repeatedly go back and forth to determine a small difference then I'd argue it can and should be ignored.
Hi Robert hope all is well, thanks again for the 306 service. Not selling your 405-2 are you - i need a bit more power........?
Coincidentally I just opened the Jult 1978 Wireless World and read a feature by James Moir titled 'Valves versus Transistors' which reports on a Quad commissioned listening test comparing the 11, 303 and 405. The speakers used were Yamaha NS1000 and the source a Studer A80 running at 15ips.Back in the old days where 16 ohm loads were common and designs rarely fell below 8 I can see why the distortion spec alone would largely determine quality.
I'll try and post scans somewhere soon.
You can guess the outcome though.
Paul
Paul
