As mentioned above the 50e is totally different to the 303. Almost like a valve amp but with transistors used instead in its overall topology... it even uses a "split load" phase splitter!
Have you heard one? If so, were you impressed?
Mmm..I was thinking about a situation where the tape input is already in use for something else. The question I was really asking was whether anyone has experienced having their 33 "modernised" by Amplabs?The 33 works perfectly well with a CD player. Use the Tape input after moving the sensitivity screws to the H position. I use my Quad CDPwitj it’s full 2.4V output into my 33 and can easily get up to volume level 5, 6 or 7 for normal listening.
Tempted by the back panel upgrade?
