The Stirling LS3/5a V2 (11 ohms) should work very well with the lovely 303!!
S.
They do. But then so do all the samples of the ls3/5a, all have high impedances. They just love the 303.
True, paskinn.
Just out of curiosity, have you tried/heard a 303 that contains NET Audio parts?
S.
No I haven't heard any mods to the 303. I'm a bit of a 'purist' about this. I think that these classic designs work very well as they are. Once 'modded' they change character. But as there are still loads of 303's out there, it probably doesn't matter if a few get modded. Plenty to go round.
Tempting me to have a try with my Harbeth 7's before the 303 has its service and now have Quad or H T Baker to choose from for service!
I've never heard a pair of 50Es, though I'd certainly like to, they are what Abbey Rd used back in the 1970s:
You can see one lurking on the floor under the left Tannoy Lancaster.
I've got my first pair coming in for a service soon. I'll let you know how they perform. The owner drives them with a 34 and says the combination works well.
Fed from a TD124/Dynavector 507/Decca.
His 124 has a few issues with rumble so I've pointed him to your mammoth 124 rebuild thread.
Thanks to everyone for the kind words of recommendation. Much appreciated!
Mmmm, Nice!
Isn't the Quad 50E just the same as a Quad 303 with one channel disabled?
Yes, I know there is an output tranny in the 50E.
I have done this in the past with good quality stereo power amps, (Not Quad) bought two and dis-abled one channel in each = much better reproduction 2x mono'd than a single stereo.
Much Fun.
Yes its half a 303 with a matching transformer.
Running half a stereo power amp by disconnecting one channel if often better than trying to bridge the two channels of a stereo amp, unless you need the extra power.
Mmmm, Nice!
Much Fun.
I've just had a 303 that I picked up cheaply modified by Net Audio. The actual work took way longer than anticipated and cost a lot more than I was originally quoted, but I ended up with the full Mk 3 upgrade. I must admit than when I (eventually) got the 303 back I was underwhelmed by the result. Fortunately it still sounded like a 303 to me, so I felt that at worst it was an expensive waste of time. So I just shrugged and carried on listening to music. After about a month I found myself thinking, "the system is sounding pretty good". Bass was more controlled and the highs a bit more extended, but still smooth. Soundstage seemed to extend beyond the speakers; I only have a small room and the speakers are close to the wall, so I can't really comment on soundstage depth (I'm using a pair of single driver John Blue JB3s, BTW). Rhythmically everything just seemed to have more 'get up and go'.True, paskinn.
S.
