left channel
Prominent Member
I will also contact Pro-ject and ask them to clarify this.
I look forward to hearing their response. The authors of the above articles used the Stream Box as a Roon endpoint, and I believe Audirvana and BubbleUPnP are also options.
None of them say the Tidal app inside the Stream Box supports MQA. And to use Tidal's own app on your PC you'd need to connect via USB, using the Stream Box as an overpriced USB cleaner only. Not worth it. But network streaming solutions like Roon, Audirvana, or BubbleUPnP could do the trick.
The operating system inside the Stream Box is based on Volumio, which as far as I know does not officially support MQA, but people have gotten Volumio to pass MQA signals to the S2D by using Volumio as a streaming endpoint. If the Stream Box could do more, Pro-Ject would certainly be marketing that as loudly as they can. But there are possibilities.
