Stunsworth
So the DAC arrived this morning. First impressions...
It’s tiny. I thought it would be small, but not as small as it is.
The remote was built to a price. A very low price. I was hoping it would use the same control signals as my M-DAC, but no such luck. There is an optional metal remote available, but that costs around £60, so I’ll be sticking with cheap and nasty (more cheap than nasty).
It look me ages to get it working. At first all I heard was a highly distorted signal. After much faffing about I tracked it down to the USB isolating transformer I use in cable between my Mac Mini and DAC, or rather ‘used’, once it was removed everything was hunky dory.
The linear power supply works fine. The only issue was with its fan. When I saw the fan I thought it would be thermally triggered, but no, it was on all the time - and easily heard from my listening position. The seller recommends disconnecting the fan if it’s too loud, so off came the top of the box, and one snip later the fan was disconnected. After a few hours the power supply is barely warm, so there shouldn’t be any problems.
I use Roon and HQPlayer for playback. I’m currently experimenting with playing everything as DSD - I do have a handful of DSD albums as well as PCM. I’ve found with my 2012 Mac Mini I can’t oversample PCM to anything higher than DSD 128, 256 and higher just gives a highly distorted sound, I guess the processor can’t cope.
Finally, sound quality. Nothing to tell, I’ve got an ear infection which means my left ear is crap at the moment.
