Mark Dirac
To be clear Dimitry, is it the case please that if you use the supplied external S2D PSU, and you do not use your special non-standard smart power cable, that the S2D works as expected?
I agree, for me Toslink sounds far superior to USB direct into the computer. However, I recently got an USBridge and then the sound through USBridge is slightly better and also supports up to DSD512 native (I am very impressed by the USBridge, excellent price/performance).Hi @JohnW
The reason I ask - the Toslink input sounds really really good.... and even sounds super focused which I can't always say about Toslink with other DACs.
We will not allow MS to spy on what software we install / run with Windows10.... its NON of MS business.... Windows10 reports almost EVERYTHING back to MS.
A little smoother but still at least as detailed. Bass feels pretty similar. Toslink sounds a little harsh (digital?) in comparison, but its not night and day difference.Agreed, Toslink kills USB direct from computer for me too.
In what ways does the USBridge sound better to you? Is the Allo smoother than Toslink or a little more detailed/brighter? And which one has better bass for you?
Hi there,
Anyone knows what is the real life current needed, less than 1amp for sure but how much? Building a power supply now...
Thanks!
Hi,
makes sense, so I hold true for now that a continuous 500mA is enough. Still looking for the data which is nowhere in sheets and specs...
Beside the current, which is a number I still long for, can some of you smart users answer this please:
- are early bugs fixed, included patch to avoid the DAC's internal DSD channel swap issue?
- is this unit reliable, as some pretend the knob is poorly adjusted and scratch the case, or that the Mini USB socket get loose in the case easily?
Thanks again,
Matthieu
Thanks, are thoses pops and clicks full volume ones or relative to set volume level, as full 2V pops and clicks are a no-no to a power amp.
IMO that's a lot of issues and quite a slow debug for a no more brand new gear, so the amount of 350€ is held, no purchase right now. BTW, is there somewhere where the log of firmware versions and fixes is held?
