One of the ways this could be explained (I suppose), is if the circuit board is made with oversize bolting holes and is bolted really close to the back wall of the enclosure. One may want to open the case and examine if the board can be repositioned slightly for a better alignment of the input socket. The other explanation is either incorrectly manufactured USB socket or some solder overflow during the manufacturing process that blocked a bit of the socket...And maybe some foreign object in the USB socket preventing full engagement. I would put a strong light into the socket to make sure it is free from any degree.
Micro USB socket is notorious for being flimsy, wearing out and generally being crappy way to pass power. Standard coaxial jack (5.5/2.1) is also quite easy to damage or have loose contact with. It is unfortunate that they became de-factor standards for powering audio equipment. I purchased an inline micro USB tail with a small power button, so I can power this device down when not in use WITHOUT pulling the flimsy micro USB connector out. They make it for a small computer called Raspberry, or something like that.
Mine is like yours, i.e. micro USB plug only slots half-way in. It's never caused me any concern, 'cos I have often seen this on micro USB devices. In fact, when I buy micro USB leads I check for an extra-long plug like this, because I have two devices (a Wileyfox Swift smartphone and a bluetooth keyboard) where many normal-looking microUSB plugs are annoyingly too short.Then how come Dimitryz’s goes all the way in. Who in their right mind would make a power socket on anything where the plug doesn’t mate all the way into the plug, except in error ?
My plug looks identical to that. Although I reckon it doesn't plug in quite as far as yours seems to. Mine seems to protrude about 4mm. I guess our sockets could be different.Dimitry - Does your original supplied PSU connector look any different to this ?
I examined my plug closer. While it is a little more in that your photo, it still proud of the back wall by a couple of milimeters.I think as Dimitry mentioned, he is using a 3rd party cable, which may have a Micro USB plug that is of a different spec ?
There is no shuffle room on the PCB for relocating the socket without a redesign of the PCB layout, so that's not going to happen.
It's built to the USB spec to allow compatibility. I think there would be more complaints if it was designed to fit only one bespoke Micro USB PSU from one particular manufacturer.
Cheerz - Brownz.
Guys,
can some of you give the other gear it's plugged into?
Also, what is the final word on OEM's SMPS vs good real filtered low noise/ripple LPS?
All here who have tested these things agree that using an external PSU provides a larger improvement than adding a USB accessory to clean up the power and/or signal. In my case I heard roughly 90% improvement from external PSUs, and 10% improvement from an anti-jitter accessory. I tried removing the external PSU and supplying clean external power through that anti-jitter accessory, but heard no improvement.
John has also recommended that we use only linear or battery PSUs. I hear no difference between the stock switching wall-wart, a cheap linear wall-wart, and a smartphone battery pack. I would hope I'd hear a difference if I tried it with a linear PSU the same price as the DAC, but I am not planning to do further testing. (I have an UltraCap LPS-1.2 on order, but that is for my ultraRendu.)
@left channel Many thanks. I hope Project are not relying on this forum to record their software changes.
We will release a bug fix update for ProJect, hopefully this will be the last official release, we will be no longer working with ProJect so this will be a "Clean up our room" before we turn the lights out type deal... ProJect has never offered to pay us for software updates so there is little incentive apart from good will on our part to resolve issues. I feel responsible for "Bugs" so do plan to fix them once time allows - Its not so simple with MQA certified units as we have to run past any updates via MQA for approval... this in its nature adds a layer of extra work that we just don't need...
Although I will no longer will work with ProJect, we have been working on the sidelines on a fairly advanced software release with extra features we have been wanting to add to the DAC, so once we have it ready (its still a lot of work and not a priority)- we will release as a unofficial update at a small nominal cost to help cover our development man hours and pay for the Pizza's ... much depends on the level of sound quality upgrade it brings....
