Oh, yes HK ST8 still in my office system -
thread here - I have a rebuilt Lenco L75 with AS-212 arm to try in office system too...but I simply love the looks of the Harmon Kardon
I'm over the stupidity purchase thing now, and looking forward to rebuilding and hearing this. Will it knock my modified LP12 off it's wall shelf?
Thanks, Richard
Hi Richard,
I think it will be hard to knock your LP12 off, I don't say this bc I'm such an LP12 fan, as I think I'm not..but rather bc I think your LP12 has a few specs that make it quite hard to knock it off simply.
Within the classic range of things, that is.
We did the same things in the past with the Sole, and that is why I think it's not too easy,,,second part being your Mission arm I really like..
I'm curious how this turns out, I would be happy if you managed to get above the LP12 by your efforts with the TD124.
Not knowledge, but plain guess is telling me that'll be hard bc of your version of the Sondek,,,you did it too good, perhaps..
We happen to do very similar, but not exactly the same things now & it's a shame Swizz is so far.
You got the HK tangential, I got a Techy SL10 tangential to explore into direct a bit..
You got the Lenco, I have started off a Lenco project..
Now you got this absolute beauty & I landed some, well in common sense maybe the absolute opposite, but I like it a lot.
Looks a bit as if Citroen would have created a deck in the 80s.
I'll tell more once it has landed..
If a bit of crosstalk is allowed...Did you compare this HK with Rabco arm to some Techy like SL10 for instance..?
I take it the arm on the HK is a bit more competent than the tiny SL arm,
generally, how would you describe the sound and which system is on.
Does your LP12 totally destroy it or..how far are they apart in your view..?
Congrats again & good luck with the TD !
