I braved it and applied power.
John - exactly what number would you like the rails to be? Set to 15V atm.
Not tried playing music yet.. It's late, I am tired and it needs voltages double and triple checking under load. But I am pleased to see the Mdac spring to life, and no magic smoke escaped.
Morning John and all, I turned on my M-DAC this morning and started to play via USB from my Audiolab 8000DT (same as I do pretty much every day) and was presented with the dreaded crackling coming from the left channel
I have never experienced this before and was quite alarmed as I had the wick turned up considerably from the day before, fresh underwear was very nearly required!
I immediately stopped playback and turned down the volume then tried playback again, the crackling was still present on every track I until I got to Kate Bush Hounds of Love Vinyl Rip, does the M-DAC like Kate or was it the fact that the rip was 24/96 that 'fixed' the issue? everything else played back fine afterwards
and Sam, your DC PSU looks fantastic I am a beautiful shade of green, enjoy!
Martin
Hi Martin,
What's your MDAC software version?
If its not the later A08/A08 then there's a very slight chance of the occasional left channel crackle- - in most cases it will be very rare indeed.
I'm on the very original A0.90 and have NEVER experienced the crackle - but then I only use 44.1KHz /16 (CD)...
John
John - Problems.. :-(
All rails on the diy psu are 15V (+/- 0.1v), and the minus ones are minus 15v, Mdac reports digital rail as 14.3v..
Sound coming out of right channel only and sounds weak/distorted. No sound from left channel unless volume turned up.
Have reflashed firmware update to original 0.9, no difference. Checked using headphones and get the same issues.
Any ideas?
Thanks,
Sam
Sam your DC input ONLY wiring is different to the earlier posted image - make sure you follow the wiring connection details below, they are based up on the colour coded wiring from the lead of your AC adaptor - apparently not all MiniDin leads follow the same colour codes.
I stress that the wiring colour code is based upon the cable removed from the "Standard" AC adaptor...
Cable Colour Code (based upon AC Adaptor cable) for Sams DC ONLY input modified MDAC:
Black (Do not Connect)
Ground (0V) Shield (via Black cable)
Ground (0V) Brown
Ground (0V) Red
Ground (0V) Yellow
Green +15V Digital
Orange Left +15V Analogue
Blue Left -15V Analogue
Violet Right +15V Analogue
White Right -15V Analogue
John
I know you're a busy man John but if you get the chance could you check my posts on page 44 of this thread, I had a faulty M-DAC unit the other week with the 'No Comms' messages and have just received a replacement unit which also seems to be faulty, this time the remote control doesn't seem to work.
http://www.youtube.com/watch?v=ZdPBUTFJ3yA
Any ideas on how I can fix this without having to send the unit back once again, or would you advise I make another RMA?
Kind Regards,
James P
Links to the posts:
http://www.pinkfishmedia.net/forum/showpost.php?p=1860791&postcount=646
http://www.pinkfishmedia.net/forum/showpost.php?p=1860867&postcount=653
Okay, still having troubles and am sure its something I have done so just want to run through exactly what has been done.
I used the cable from my MDac psu, so no mini-din wiring needed.. As my mdac is DC modified it was of no use anymore. Followed exactly those colour codes (and double checked a moment ago).
Checked output from my regulators and they are now exactly +/- 15v as appropriate.
Black wire is not connected, taped off. No stray wires etc and all solder joints look good (got a good light and magnifying glass on them)
My only thought is the 0v connections.. I have 3 different 0v pads (due to the 5 seperate windings and 3 rectifier boards), checked with a meter there is NO continuity between the 0v pads.. Currently all 0v wires go to the same 0v pad.. If you tell me which colours are 0v for which other wires I can put them all to the correct 0v pad, or maybe I would be better off joining the 0v pads together?
Thanks,
Sam
Hi Sam, yes, all the 0V on the PSU should be connected together...
In the lead there are 2 black wires - one that's join onto the outer shield wiring - this should be connected to 0V the other is a "Real" black wire that was unconnected in the original AC PSU, keep this one unconnected...
If no luck, PM me your contact number and I'll give you a call...
Only one black wire, and a 'silver' wire that was not insulated.. Silver wire showed continuity to the shield/outer casing of the mini-din. Black wire is taped out the way.
Will link all the 0v points together now and see if that helps.
Sam
John i've got a question concerning burn in. Is it feasible using headphones or is it better to connect to a switched on amp ?
Moreover how many years does it needs ??
br /
