I have revisited 0.90 firmware for couple of times now. I would like to just say that its the best one. and i tried so hard to agree
, but here is my subjective findings:
0.90 seems to have the easiest to listen to sound or nice an smooth laid back sound. You cannot go wrong with it. It won't bite you.
It has wide stereo image, but i think that sometimes it can sound a bit flat. Analog sounding, yes, maybe, but everything seems to sound a bit too smoothed out (smeared?) especially for electronic music. Many of them effect sounds used in the genre (if you know what i mean) are not perceived in the 3d listening stage, but just panning l<->r between speakers.
The bass is nice, but dunno if it is fully extended. The rhythmical of the bass side is handled well tho and the bass is firmly placed in the sound image. I think that it is missing some of the definition and air that the later versions have.
0.99 has totally different bass and it seems to be as wide as the whole sound image. Bass without proper firmness and placement cannot sound good.
What
finesensations suggested (A.05, partial d3e, 0 deg) sounds ok. It has more space and air, the bass is firm and placed properly. The difference compared to 0.9 can be described with analogy of watching a movie few rows closer. The sound stage surrounds you better. The bass (impact) could maybe be just a tad lighter, but it sounds fully extended and well balanced with other instruments.
I was and am totally happy with the 0.90 but i also like the extra "sharpness" or definition in some of the later versions.
