synackle
Member
A question, the EDO (Enhanced Digital Output applet by Triode) has several benefits, firstly it turns off unwanted functionality such as the SBTs onboard DAC, gives a more 'optimised' linux kernel, but it also gives me an option of using USB out. I notice that in the applet notes it states that the M-DAC is one of the devices it's been successfully tested with, using the native USB out. Have you had any contact with the developer 'Triode'? Or is this something he's developing in isolation?
FYI I'm using COAX at the moment, but I may experiment with USB once everything has 'bedded in'...
I'm using EDO with my SBT, connected via USB and it sounds wonderful. I remember a distinct improvement over coax. I did however need to connect it via a USB 2.0 hub to get the connection to sync properly (it correctly converts the SBT's USB 2 signal to the USB 1.1 required by the M-DAC, for want of a more precise explanation)
Now I wonder what benefits a USB isolator between the M-DAC and the hub would offer...
