I think from what i've read it was mainly cable/sky/freeview boxes that have been causing the dropout issue, i emphasize the 'was' as its a non-issue now
I agree that the SQ improvement for films/TV is very noticeable
If you are running Windows, J River media centre will do exactly as you require i.e. add a selectable amount of silence to the top of "new" playbacks but not interfere with gaps (or lack of them) between tracks.If anyone has any other suggestions for software or otherwise I'd greatly appreciate it.
Actually, it's a conscious decision they've taken to prevent the propagation of malware and other such nasties via their email system. I should think that anyone who had need to send an .exe file would be savvy enough to find another method, and I'd rather that than act as a vector for the myriad ill-ware that pollutes many other providers.I was just surprised that Gmail does not allow .exe files - that's so amateurish... We work with exe files on a daily basis - I guess it indicates Gmails target market...
Hi All
I’ve been following the Audiolab/M-DAC threads with great interest.
I have seen mention of the M-DAC comparing well or bettering TAG components. I wonder if anyone has actually substituted a M-DAC in place of an AV32 DP in a TAG system containing a DVD32R or DVD32FLR feeding an AV32R DP where they were connected using the synch link which was itself designed to reduce jitter.
I would be interested in hearing exactly what was done (replacing the AV32R DP completely or bypassing the AV32R DP internal DACs) and their opinion as to the relative merits. And for the purpose of the comparison maybe with the AV32R’s TMREQ turned off.
When the M-DAC becomes more available I will try to borrow a unit and try it myself but in the meantime I am curious as to whether anyone has already done it?
Hello John and allThat confirms my findings exactly...
Using the Optical out on my V+ box, directly into Input OPT1 (DPLL Auto) on the M-Dac i get dropouts frequently (around every minute for a split second)
If i use the HDMI out on my V+ box into my TV, then the Optical out from my TV to the M-Dac (Input -OPT1) i don't experience the frequent dropout
Although i do get the feeling i may experience the odd very rare dropout as i observed this same thing before (drop outs from V+ box via optical frequently, dropouts from TV via optical infrequently)
Using the Optical out on my V+ box directly into OPT2 Input (highest DPLL BW) on the M-Dac there is no dropouts at all & the bitrate toggles from 47k to 48k+ constantly (for example switching between 47.681k & 48.322k)
So it seems using OPT2 (highest DPLL BW) solves the problem just fine
Hope this helps, sorry for my possibly long winded method of explaining what i've found
Hi all,
I got my new M-DAC three days ago and so far I am very pleased with the sound quality which improved noticeably within the first 24 hours. After re-reading some of the comments by John regarding burn-in, I've decided not to cut power within the first 14 days.
I did a quick test with my Lenovo x121e subnotebook, foobar2000+wasapi and a bunch of flac files i ripped from selected cds. Both (new) Bitperfect testfiles provided by Dominik several days ago passed without errors. SQ via USB input is very good however i can only compare it to a Pioneer LX52 bluray player which serves as my cd transport for the time being.
On saturday i received the last missing parts for my new HTPC build. I use the lovely OrigenAE M10 mITX case with an Asus P8H67-I Pro motherboard, Intel Celeron G530 CPU, Corsair DDR3 SO-DIMMs and (for now) a Hitachi 2,5" harddisk drive.
The HTPC works fine, I passed the Bitperfect Test both with foobar2000+wasapi and MediaMonkey. But the system is generating some serious noise (no, it's actually very quit, i'm talking about electronic noise). If there is no music playing you can hear some serious stuff going on. Now I know why John is building the Transport (and it's USB input) galvanically isolated. When I power the system down it gets even worse with a load whistling sound. I have to turn off my poweramp (Cambridge 840W), disconnect the usb or turn the HTPC back on. The whistling sound also disappears when I disconnect the M10s external power supply from the line and plug it back in. The case uses an external 150W AC-DC power supply (made by FSP) and an internal DC-DC converter.
Guess I will have to do some more research regarding the noise problem and I will be grateful for any ideas..
John, I'll be very happy to beta test your transport..
Michael
Hello John and all
does anyone using Cambridge Audio ID100 with M-DAC??
I am using the coax input with my Cambridge Audio ID100 , the clocking is unstable , and music cutoff and in every few seconds ..
does using optical connection with ID100 solved this problem ?
is there any firmware that I could update to M-DAC to solve this ? I am using MacAir and using iTune to play.
Please help !
How to fool almost any provider....as long as they allow ZIP files!
Use the free 7 Zip program to make an encrypted wrapper - make sure you select the box to encrypt the file names or Google will see through you.
At the receiving end, unzip the received package and voilà!
A Mac-compatible alternative is to double ZIP i.e. ZIP the ZIP a second time, both passes encrypted with the same password. The double ZIP approach is necessary because standard ZIP encryption does not encrypt file names, thus revealing your transmission of an .exe file to casual inspection. Once you ZIP a second time, all that can be seen is the file name of the first ZIP, not the names of the files contained within.
The pending software update we resolve the issue - I'm guess first full public release at the ends of this week,
John
Hi John,
Do you have a list of which features made it into this upcoming release?
Ben
X2 , and most important thing is that how can user be informed on the update and installation ?
will the dealer / distributor worldwide be aware of this and provide upgrading service to their customer while needed.
Raymond Lim
Here we go...
There will be two software builds.
1. The Official Audiolab build which corrects known Bugs and issues.
2. The "Lakewest" build which adds extra features and owners requests etc - this way we don't have to get all hung up with user manuals changes etc - and the "committees" who argue endlessly about the befits of adding features.
I have no will to entertain dealing with the official channels - I'll be more then happy to support owners on PFM and anyone who comes to us directly.
We no longer work for Audiolab, however we are happily offering free support simply because its the correct thing to do
John
Just as an aside, which V+ box to you have? I got one of the "new" Samsung ones a few months ago as I was having lots of problems with my old one (I forget what make it was). I watched it for an hour or so last night over optical and had no drop outs.
Ben
John
