adamdea
You are not a sound quality evaluation device
John seems to think that the output stage is identical. But maybe the rectification is improved.Yes whether just changing the transformer alone would make a big enough difference is hard to say, but if it didnt then EI transformers might be used exclusively. Which i assume the mdac uses. Johns orignal power supply upgrade which he called M-pwr i think, also included a redesigned rectifier stage. I think the torodials main attraction over EI is its ability to contain its magnetic field, which may be desirable for creating a clean power source.
From glancing at the circuitry as i pointed out, the output stage was very similar. But there are various component differences in the rectification stage and gain stage that make me ponder.
I agree with you about the EI. So taking an external EI and replacing it with an internal transformer may require a toroidal to avoid problems
This seemed like an interesting article
http://www.soundstage.com/maxdb/maxdb071998.htm
