Basically the test where conducted to gain further insight into a theory of operation thats applicable to both FDAC and MDAC, and if anything is relevant to the Detox (WRT further improving its performance).
Hi John,
Does this mean the 'optimal' position might be different depending on USB source or other factors? Or will it be 11-12 O'clock for everyone.
Also, have you tried Detox with a non-modified MDAC to see if the result/improvement is the same?
Thanks, John. So Renata is fully involved and you have the bruises to prove it!
Wrt that article on RF intermod, but for the ubiquity of mp3 audio it might have been properly dealt with 25 years ago. Strange how things turn out.
Then try it with a five Calex Psu.
Speaking of which if you could identify the wiring on the 10 pin connector CN1 on the main board please as the service manual is non too clear.
Thank you.
Thank you.
Perhaps I'm missing something, but why 5? Wouldn't 4 do ?
Paul, don't make me build a new MDAC PSU!
Paul, I'll have to draw it up on Paper and post here - I'll try this evening, I'm still updating the Detox PCB and have come down with some kind of bug thats knocked me out these past few days...
So basically this needs to be modified for five rail DC input on CN1?
this leaves me to find a supply for the remote r/c pin 9. So maybe 6 Calex's
You need to connect to CN2 (well the main power cable to the MDAC PCB) - but not you loose the Power switch, so you need to switch the MDAC via the PSU / AC socket.
