JohnW
pfm member
Having sections in a copper lined Al CNC milled chassis to provide RF-Screening/Isolation much like the Detox may be a further improvement for the FDAC.....this type of design advantage could outweigh the extra production cost?....especially for the enormous number of screws this may require.
It certainly would, and I could use the Base as the heatsink for the output devices and PSU - which reduces the mechanical parts required and helps improve dissipation. Heat is radiated directly into the chassis rather then needing to rely on radiation from internal heatsinks with increases the internal operation temperature.
Last night I start to look at ways of reformatting the existing MDAC2 design around a milled base / possibly complete Chassis. The Base could be milled, and the "Covers" could be an optional cost extra cost for those wanting the very best
The Detox 'rats nest' looks scary....can't imagine what the FDAC 'rats nest' will look like....you may need to issue an R18 warning before issuing that .![]()
The FDAC Analogue stage is a fully discrete SMD design - I've spent a couple of years designing it via Computer simulations - then direct to PCB and it worked first time
Here the original MDAC2 PCB being tested on the TDR to confirm the PCB characteristic impedance (critical for the PECL base clock distribution).
https://dl.dropboxusercontent.com/u/86116171/MDAC2 TDR.jpg
https://dl.dropboxusercontent.com/u/86116171/MDAC2 TDR 2.jpg
You can see the TDR sampling head connected to the MDAC2 PCB via Semi rigid Coax Cables - these cables are very expansive and supplied as matched pairs for this differential TDR application.
Note the ESD connection caps sitting on top of the sampling head - the Sampling head is very sensitive to static discharge, any voltage over +/- 2.5V will damage the head - the heads costed new about US$20,000 so it makes for a bad day if you damage one... still at least you don't have to tell the "Boss" :-
https://dl.dropboxusercontent.com/u/86116171/Sorry Boss.jpg
The MDAC2 Analogue PCB during testing:-
https://dl.dropboxusercontent.com/u/86116171/IMG_7261.JPG
https://dl.dropboxusercontent.com/u/86116171/MDAC2 PCB.JPG
