You've missed nothing so far. What speakers are you driving?
This may come as a surprise, Usher BE718s
They're relatively inefficient,
http://www.stereophile.com/content/usher-audio-technology-be-718-loudspeaker-specifications
so as with any amplifier you use with them it will depend on what distance you sit and what volume you listen at.
http://www.stageaccompany.com/support/calculator.html
According to Wiki ''The project has been officially kicked off on September 5th, 2013''
So about 2 years.... CD-transport to mention just a few extra dimensions). John should be doing listening tests around xmas I expect.
Nae bother John..
@JohmW
Sorry for the offtopic: John I have the 8200dq protoyype you sent me for the... let's say lost dacapo board. Well the analog preamp part works but the if I use the digital inputs, they only output one channel. The headphone outputs both the two channels ( at least it worked this way until the headphone connector broke inside muting the 8200 and I had to remove the headphone board).
What should I check?
Alex,
I'm not a big fan of the AP systems - I have 4 of them in my lab, and I cannot think when I last powered one up. They are OK for production line testing but I find them pretty useless for bench R&D work - what I find most useful is a High Resolution wide bandwidth FFT system - I personally use Audio analyzers from Rohde & Schwarz which are far better for "real time" bench work.
I recently purchased a fully loaded Vector Signal Analyaser system from Agilent / Keysight. The VSA is basically an RF BW FFT system. This allows "real time" FFT analyses across a wide BW so I can observe the spread spectrum clock modulation etc.
The VSA is useful for the spread spectrum clock circuit development but its still not ideal for the realtime 500MHz BW required for the USB2.0 signal as its limited to a RT BW of 85MHz or some such.... Still I'm very happy as it arrived just in time for the Detox clock circuit development.
Its a real challenge to measure across such a wide BW with high dynamic range - I use various signal source / integrity analyzers from Keysight and Wavecrest.
The first thing you need to buy is a differential probe (atleast 1.7GHz) - this will set you back around US5K (although I think my probes are 6GHz or some such).
The problem is that nobody really cares about the signal content of the USB datastream at such a critical level - and I'm not aware of any system that has the required dynamic range at a realtime 500MHz BW... so you have to either perform indirect measurements or limited BW measurements. Its always a trade of between Dynamic range or Bandwidth even at these silly prices.
A decent FFT analyzer + high performance scope with Diff probe is a good place to start.
Next, try and arrange a demo of a real time spectrum analyzer from Tek such as there RSA6000 Spectrum Analyzer to see if you can capture the USB data with a usable dynamic range...
I have seen some used Wavecrest DTS units at fair prices, but again, that my not be our priority at this point.
Alex,
The Wavecrest DTS units are nothing more then glorified time interval counters and useless for John's needs.
- I use a SIA4000 and ScopemaX units. The SIA4000 has quite poor LF noise performance (the SIA3000 which are quite common are even worst), but the ScopemaX is much better.
Well I have talked about a TDAC - but now the FDAC uses paralleled MOSFET devices in its frontend analogue circuit I suspect the difference will be very small - so question the need for TDAC.... lets see.
