Naaaaa
Totally agree
Naaaaa
Impressive
My M-DAC needs to go back to Audiolab for repair (the coax input 2 socket came clean out still attached to the cable!).
I have taken advantage of the extra features that are available with John's firmware updates, but does installing this invalidate my warranty? I don't see why it would... but I know this is the best place to check.
I see that the original Audiolab firmware is on the wiki but as I use Macs I would need to borrow a PC friend to reinstall the original version. It would be much more convenient to leave my M-DAC as it is, but I don't any issues with the repair process.
JohnW
You can just push back the round Ground collar with its plastic orange insert back into connector, just insure the 2 "prongs" on the collar are rotated correctly. On MDAC2 we will use the audio output type connectors for the digital I/O's.
Jonathan,
Its not you who should feel a little daft - but Audiolab that they still have not resolved this issue!
As I say on MDAC2 we will use the solid Milled RCA as used for the audio output RCA's.
Glad you "Fixed" your unit![]()
The clock locking system used by Deltec is called Deltran Locked and information can be found here http://deltecprecisionaudio.com/deltran/ On a good system the different is huge. It will transform a budget CD player into a super transport and it has been professionally designed to fit into a XLR size mounting hole. You would find similar results with other DAC systems.
I have been rather surprised that lots of M-dac owners have not tried using the clock out. If you don't believe that all transports sound the same then it makes no sense to have a CD transport and not use the facility (or at least try it).Thanks, the picture helps a lot to see what's needed. I guess you get involved in hole drilling/punching at the right place on the back panel of your CD player, unless you are lucky enough to have a player with a spare XLR which you can sacrifice.
However,
"It will transform a budget CD player into a super transport"
doesn't seem to be what Hi-Fi Choice found, and that's why I asked what experience people had had with the MDAC.
<snip>
On the other hand, cd players which will take clock inputs are not thick on the ground
"It will transform a budget CD player into a super transport" doesn't seem to be what Hi-Fi Choice found, and that's why I asked what experience people had had with the MDAC.
John,
Is the M-DAC2 the user-replaceable PCB project that members are contributing to on a monthly basis? It sounds very interesting.
The simultaneous XLR & phono output would be very useful for me, as would the built in attenuation (I'm using Rothwell XLR attenuators currently). And I'm sure I read somewhere about the possibility of an analogue input too.
I'm sure I also read that you'll only be producing one batch of PCBs. It won't be a retail product as such.
Thanks, Jonathan.
When and where can I buy the up grade for my Audiolab MDAC in Italy? There has to install it? Can I do it myself? It takes a technician does it cost? Thanks for your kind answers.
Dario from Italy.
and one MDAC which needs it's relays fixed![]()
Great news, I'll email Renata about the details.Well Relays replaced and its been updated to latest Fusion Spec. to be quite honest my system sound Sooooooooooooo much better with your Fusioned MDAC verse the CDQ I've had in the system prior that I cannot make a judgement on its sound quality - its like comparing Chalk and Cheese...
