john dolan
Lars,
Peter has already correctly answered, the wiring indicated would short out the negative phase which would make the MDAC run quite hot - and possibly damage it in the long run, the MDAC is not designed to operate into a permanent short circuit.
As Peter says, what you need is:-
XLR Pin 1 (GND) -> RCA shield
XLR Pin 2 (+) -> RCA tip
XLR Pin 3 (-) -> floating (Not connected)
Thanks John
Went to Maplins and bought a couple of plugs and fitted them to the ends of my Chord Anthem cables wired as per your guid sounding fine thanks again.
