Could we play Vinyl direct through the MDAC then. ? ( using a suitable Phono stage )
I.e is analogue to PCM/DSD conversion done on the fly ? or do we need to rip to a hard drive first.
This for me is indeed the last piece in the puzzle!
Full DAC with Analogue input with volume control, and bluetooth for the wife! = no need for an extra preamp box - right?
John i'm currently having an issue with Vinyl through the analogue in of my current DAC (MF M1SDAC) where the analogue 'line in' is limited to 1volt so i get clipping on loud recordings, what will the equivalent voltage be on the MDAC2 for the analogue in?
Hi John, sounds great!3. DSP+ Bluetooth + Analogue attenuator + Hi Performance ADC (+ GBP200 + Analogue attenuator & ADC materiel cost).
If an ADC is added it would be nice to mix the analogue input with one of the digital inputs for some applications (i.e. music instrument, mic). But here I'm assuming there is little delay between the analogue input and the output.
Am I correct that the ADC will be using the analogue bypass inputs?
Just wondering if I'd be able to connect a turntable without having to disconnect my AV processor from the bypass.
If there's any way to leave them both connected, then this sounds like it will meet all my pre-amp requirements without any extra boxes, which will make it easily worth the extra £100 alone!
Even with ADC the MDAC2 isn't a PreAmp with fully integrated analogue input, right?
No, the ADC is NOT required for room EQ, although you will need some way to measure the room response - with a Microphone input - most PC's support this Mic input.Did I need ADC to get RoomEQ or better RoomEQ?
sounds more and more promising, a built in upgradeable DSP multitool, but if it has option of RIAA EQ, will it then be necessary to have a gain stage in front, for high output cartridges ?
There is already quite some delay in the digital input path (when using a PC). But I wouldn't like any delay in the analogue input either!
Would you like to make guitar/bass effects?
I'll try
Hi Rob, Yes correct - but you would still need an external phone pre-amplifier if you wanted to use a turntable.
The ADC input level would be set to 2.2Vrms, but we can customise this level if required with a simple resistor change.
Yes, thats the idea You can use with a conventional Phono Pre-amplifier - at a later date we will design a very high quality Phone "flat frequency response Gain Stage" which will amplify the low level MC /MM cartridge output, and the MDAC2's on-board DSP / FPGA will perform the RIAA equalization on the digital domain in real time.
JohnW, I thought that the basic unit which I was purchasing already had DSD support? is this now a 100 upgrade bundled with bluetooth and analogue input?
http://mdac2.lakewestaudio.com/
Thanks John.
i would suggest that you test this with some loud recording singles and a high output MM cart. As i suspect that 2.2Vrms may not be a high enough ceiling for some powerful phono stages crossed with some loud 45rpm singles.
You mentioned that the analogue in will have attenuation - would the attenuation sort the above issue?
