graham-r
I don't have the circuit for the device you are using so can't comment on that, but in the case of the Velleman circuit the start up delay is ultimately controlled by the time taken for the psu to stabilise the output offset.Well the cap is already 100mfd. I will check the resistor though. However, I was not at all impressed by the pcb itself.
Andy
Testing my version of the Velleman circuit usually settles almost immediately when being tested in isolation as there is no DC voltage present.
Using this circuit on a single rail supply will probably take longer than a dual rail - this was certainly the case on a Sugden A28 for example.
