Craig B
Re:trophile
It is unusual for a 2-way loudspeaker to go dead silent, as opposed to no treble (common) or no bass (less common). Unless seriously abused, dead silence is often down to something less serious than blown, and possibly difficult to source, drivers. Could be as simple as a cold solder joint on either the +ve or -ve binding post connections within; something that can arise should one post be loose and free to turn whilst tightening the nut, for example.I have a pair of white JPW Mini Monitors that worked like a charm for years. Out of the blue one of them went dead silent. I have done all the rudimentary troubleshooting (switching cables, different amp, switching left and right), and it’s clear one of them is not working. I cannot see any visible damage and all the soldered connections look fine.
Could anyone please provide some guidance regarding troubleshooting the internals? I have a multimeter but I have never done this before. Thank you!
Suggest you start by removing the terminal block from the back panel, as this has the crossover components attached and, therefore, will allow testing of terminals, crossover, wiring, and drivers all without having to remove the drivers from the enclosure. No need to cut any wires, just leave the terminal block hanging out the back.
In the meantime, I have some Mini Monitor crossover photos to share that can be marked up to show what test points and settings to use with the multimeter.
