I use 50A Anderson connectors
Also available in red https://uk.rs-online.com/web/p/heavy-duty-power-connector-kits/6120166/ makes it easier to keep left and right... I've used them on more than on amp stack.
Speakon are also good.
I bought a new so-called endurance bike last April that not only has hydraulic disc brakes but tubeless tyres. That puts me well beyond the pale as far as many roadies are concerned. No punctures so far & I can actually stop in the wet!As far as cycling is concerned I am sure that if you change your balls for ceramic versions you`ll be able to grind out better times.
Just thought that I should let you know of my experience with the the KLEI Classic Harmony Banana Connector/Adaptor. I have been using these as adapters, attached to the existing bananas, and they sound great. Just better sound, timbre, PRaF, etc across the audio range.
Others have indicated exceptional results with them also, on these threads How much difference could a simple Banana plug make? and Binding Post Jumpers - New Product!!!
From posts I have read they seem to go very well with dueland wire and helix wire.
Interesting, would love to know your thoughts and has anyone tried them?
Some speaker cables are too big/have too many strands. Some terminals are too small. Some cable manufacturers terminate their cables (some TQ cables have to be factory terminated, I believe). Some people change or compare cables. Bare copper (or silver) wires oxidise. And so on.
The space behind my power amp is so tight it would be impossible to get to the terminals well enough safely screw down bare wires.
You don't actually know what "foo" means, do you?If your speaker cables are too big to fit into the screw terminals of your amp or speakers then you have quite possibly unwittingly strayed onto the path of foo.
Sometimes I'm amazed at what I read from HiFi enthusiasts. Have read some even polish fuses. It's entertaining if nothing else."Effect they have as quantum"
I suggest you go off and read a physics text book and then you'll realise what a complete load of tosh it is that you've written.
I would also like to see some kind of explanation as to the cause of the miraculous effect of a termination? I accept there may be small differences in impedance, physical contact, etc. How do these small differences translate in to the massive changes you've experienced?
But if you think it's great then fair enough. But please try to have at least a basic understanding of terminology you use, rather than just repeating the tosh you've read elsewhere.
What is it about low mass that makes them special?Correctly terminating a cable with good quality banana plugs or spades is a prerequisite if you want the cables effect minimised. I've experimented with lots over the years. Low mass gold plated does the trick for me. Tried solder 'V' crimped, both sound identical.
Low mass = less brass = less shit/resistance in the way.
