JensenHealey
Does not explain the theory of "Mass Storage" effect. Sorry. Find a better explanation. It is utter crap
That ain't no proof, it's advertising pseudo-science!Really? Easy to find, and not new. http://www.wbt.de/english/products/a/Detailansicht/Artikel/nextgenTM-pole-terminal-6.html
No.Maybe it does, most of them are made from brass, which has a much lower conductivity than copper, and a higher resistance. Maybe having to conduct through an alloy of different metals has a storage effect ?
OOPS: forgot to ask the OP: is this a plug for the banana plug in question?
Unfortunately it is not a joke. Some folk here don't get: if it smells like BS, it probably is BS.I cannot believe this:
Is the whole thread a joke? What do they mean by "other effects?"
- to further dynamically enhance electron flow in the Signal conductor.
- to further protect the Signal from capacitive, inductive, EMF, EF, EFI, RF, static charges, and other effects.
- to further facilitate a smooth uninterrupted signal flow from the amplifier to the speakers, effectively isolating and allowing them to perform their task without interference."
I didn't make any claims for the veracity of the theory, I just told you how easy it was to find it. What you make of it is up to you. Don't try to put words into my mouth.That ain't no proof, it's advertising pseudo-science!
I'm aware of the claims (Chord also stated the same). I was hoping for some evidence that you state is easy to find. I not trying to put words in your mouth at all.I didn't make any claims for the veracity of the theory, I just told you how easy it was to find it. What you make of it is up to you. Don't try to put words into my mouth.
And that is why I won't use that type of "cage" plug. In fact some of them are steel too.i watched this recently - and kind of respect this fellow's opinion on the subject - apparently it CAN make QUITE a BIT of difference...
I've nothing against Z plugs - I use stackable ones at work. Their contact area is far better than than those worn & corroded bananas shown in the video. Multimeters are pretty poor at measuring resistance under an Ohm unless they use sense terminals (4 wire) that will give repeatable readings.i watched this recently - and kind of respect this fellow's opinion on the subject - apparently it CAN make QUITE a BIT of difference...
You should see how thick the metal is on a 7/16 DIN RF connector. Fortunately RF electrons follow different rules of physics to HiFi electrons or you phone wouldn't workReally? Easy to find, and not new. http://www.wbt.de/english/products/a/Detailansicht/Artikel/nextgenTM-pole-terminal-6.html
the what what?The discontinuity theory
I got some gold headphone jacks from China. They were shockingly bad, I wouldn't be surprised if they were spray painted with gold paint and varnished. Almost didn't conduct the signal.i watched this recently - and kind of respect this fellow's opinion on the subject - apparently it CAN make QUITE a BIT of difference...
