joel
Painter of Dragons, Maker of Mirrors
Would you care to put some numbers to that?It might be characterised with a large peak::average ratio.
It's certainly a myth that ATC actives are tiring to listen to. The danger is that you can get suckered by them into listening too loud, and this only becomes apparent to you if you have to leave the room...
i would say that with the 25 watt Sugden that i use, the SHL5s are more happy at what i would call a `moderate' level..i would put this at what sounds realistic with unamplified music. i would also say that they like to be a little bit louder to come alive than my old Audionotes.
What make and power of amps work well with the 40.1?
and the amps you would put with the 40.1s darryl?
I guess that's mean to peak? M40s will go beyond 105db@1m IIRC, but you'd have to be prepared to eq the LF.The segment of Parsifal that has just come up on the random play is about 40dB.
I believe there are fairly specific EU regulations regarding noise levels in the workplace.Really we should be getting AS to justify his assertion that a speaker apparently explicitly compromised for use in a TV vision control room is suitable for general sound monitoring or domestic music reproduction. His claims seem odd to me.
ATCs are built to be played loud
I don't think it follows.Both are designed to suit their respective requirements, and this can be seen in the frequency response.
I have reached the conclusion, and I stand to be corrected, that customers buy gear often without hearing it.
It's part of the fun.I buy every piece of hifi and speakers without ever listening first, apart from one occassion. It's a lotery, sometimes you hit the jackpot, sometimes you buy an expensive turd.
I assume you guys are either joking or, unlike poor me, you operate in a financial stratosphere I can only dream of.
Tiger, I am sure that you are more astute in your purchasing than you let on.
What amazes me, as I said before, is the amount of expensive new gear I see on forum classifieds 5 minutes after it has been bought.
