Richard Lines
I wouldn't worry to much about those caps, the feedback one has the biggest influence and as long as their axial tants above 100uF your ok, Les uses films for inlet and that's what I use but tried allsorts and its small differences, the 68uF across the bias transistor has very little influence I have a 47uF axial tant just like the one you have in feedback and that works great, think Les uses tant beads here now just like Naim.
I know in the past that Les recommended Kemet SMR's on the inlet side for Naim modifications - https://uk.rs-online.com/web/p/film-capacitors/1719416
You're suggesting going over 100uF for C6???
Regards
Richard
