That's a shame Mark you can still get the rubber bits, if you'd only known then.
I made a bit more headway with my project. After a bit of measuring and guess work I have trimmed a bit more out of the Maple block and I think it will work quite well. It means bolt heads will be visible on the top of the plinth but the 2 for the motor mount will be covered by the pulley drive cover and the ones for the switch assembly will be underneath the platter. I will give it a final sanding tomorrow and get some Tung oil on it.
The Bamboo Board prototype is sounding much better now I've found it a place on my equipment rack and done a little fettling on it.
