You'll have to come round with your copy as my Grandma borrowed mine.
The Bamboo board works fine. I think you were right the motor must have been barely touching the Maple or else it was osmosis.
I did notice the lower notes are a bit muddy/ boomy??? The First Album I played sounded great it was a 180 g copy of Eva Cassidy Song Bird but when I put on Santana's Abraxas it would not track it just played a note here and there. I raised the height of the platter and it played OK except for the lower notes, as mentioned earlier. When I was setting up the SME arm it did say that it should be parallel to the record surface but I had my doubts about that as it looks like the back of the Shure V15 III is touching the record surface. Also I am very limited with the height of the on/off switch and the motor pulley,the SME arm is as low as it will go unless I router out a pocket for it on the plinth;s surface. That would lower it by 3/8" but it would not be pretty, I'm not expecting to get "Concours de Honor" just hoping for it to not look too bad.
