by a pair of mediocre loudspeakers
Could you please tell me what are the good enough speakers actually. Because I heard top top of the line Martin Logan Neolith, PMC Fenestria and top Montanas, don’t remember their name.
Why not if it's still two channels?Of course, If yer using subs...it's not stereo...![]()
This is why I try to do A/B tests directly. I also have a very small set of test tracks that I know exceedingly well, so I have some semblance of an absolute baseline in my head. It's not perfect, but it's the best I can do.
I don't think I've heard of that. Do you have a link?By the way, I recommend to read a famous article by Audio Note Peter Qvortrup about absolutely different approach to hi-fi testing.
Absolutely. Recent experiments prove beyond doubt that power cables are the most important component in any system.You could apply the same for dacs, power cables or whatever)
Do you feel you have set them up the same way for home cinema as you would have done for music? IIRC there was a very good article (possibly by Sean Olive) above why 4 subs was optimal. I can't in principle see why the physics would be any different for cinema than music but I can see that the desired setting might turn out differently for the use case. Either way my chances of installing 4 subs in my domestic environment are precisely zero.
If you use 2 subs it is.Of course, If yer using subs...it's not stereo...![]()
For a lot of people, something like the NHT SuperOne fits the description. It's not fancy or flashy. But it gets the job done well.Could you please tell me what are the good enough speakers actually. Because I heard top top of the line Martin Logan Neolith, PMC Fenestria and top Montanas, don’t remember their name.
That's a totally different story.
Yes. And as Audiphiliacs we certainly don't want to be in the second group. So to be on the safe side we hear things that isn't there.
A couple of Audiophiles listen to some gear. One, with a assured voice: 'Did you hear it, with amp Xxxx there where a slight hawkiness in the midrange.' The second Audiophile (who didn't hear any difference) blurts out: 'Yeah!'. The third person, who isn't an Audiophiles, keeps quiet and wonder what they are on about.
It depends on the room. The only way to find out whether they are good enough is to try other options to see if they can be improved in your room. This is why dealer demos for loudspeakers are rarely useful and home dems are essential.Could you please tell me what are the good enough speakers actually. Because I heard top top of the line Martin Logan Neolith, PMC Fenestria and top Montanas, don’t remember their name.
Quite: if they're not long enough, you are stuffed.Absolutely. Recent experiments prove beyond doubt that power cables are the most important component in any system.
Audiophiles often ponder/argue whether speakers are the most important component. I remember many debates on the Naim forum regarding whether "source first" was the best approach. Some insist the amplifier needs to be awesome to drive the speakers properly. Etc.
I have a Ferrum Wandla+Hypsos combo running in both my office and the family room. My Cary SLP-2002 is currently in the shop getting some maintenance and upgrades, so both Wandlas are being used as preamps. The Wandla is an exceptionally good DAC, but I would say its preamp section is merely "good enough" (definitely below the solid-state Benchmark HPA4 and the tubey Cary SLP-2002)
In my smallish office I have the Avondale SE400 and little Ergo IX. In my larger family room it's the lesser SE200 and Klipsch Cornwall.
The family room (with Cornwall) sounds bigger and faster, but my office system sounds better overall (overlooking obvious limitations like bass extension).
The moral of the story seems to be that as long as the speakers are "good enough" (including both sound quality and appropriate room size), then the amplifier is more important. More generally, I think we need to get to this elusive "good enough" level with all our components, at which point "Source First" probably makes more sense, then on down the stream.
Anyone care to add any thoughts and experience?
