The Voyd Turntable part 1
Voyd Turntables is a small Cheltenham based outfit producing turntables of the highest quality .
These start with the Valdi at £595 , then there's the Voyd at £999 (1199 with split phase psu) and finally a strictly ltd edition Reference at a cool £5000 .
The latter item is made to order and there's a substantial waiting time for delivery due to the fact that the motors used are as rare as hen's teeth.
The turntable reviewed here is The Voyd but with a few optional extras which bring it some way towards being a Voyd reference .
Perhaps The Voyd plus would be an apt name for it.
Entry to the owners club isn't cheap: comprising the motor unit (£895) ref bearing and platter (£352) and ref psu (£1275 inc mass dampers) along with a Helius Cyalene (£1066) and Audionote IO (£895) we'll leave you to do the sums .
Quality of finnish is nothing short of superb. All Voyd turntables look the part, with gorgeous sculpted wooden plinths available in a variety of tree options . Three springs are used to suspend the subchassis, and a fundamental part of Voyd design is multiple motor drive -two motors in the cheaper Valdi deck, three motors in all others.
Designer Guy Adams describes the action of the cartridge stylus acting as a brake as the walls of the record groove try to 'drive' it . The degree of braking depends , in part, on the amplitude (volume) and the frequency (pitch) of the modulation (signal) in the groove. Low frequencies and transients are the most difficult signals to get past the stylus.
When a transient occurs the motor in a conventionally driven sprung-subchassis turntable continues to turn at a constant speed, but initially it is easier for the motor to pull the entire record platter, the subchassis and the tonearm assembly towards itself than to pull the platter and record past the stylus .
This dynamic instability is happening all the while a record is playing - and the result, says Guy Adams , is that we're not acurately retrieving all the information content of the record groove, especially in the areas of low level detail and dynamic attack.
All Voyd decks employ acrylic platters for good 'impedance matching' between record and platter (a controversial subject, this : its one thing for unwanted vibrational energy to be effectively transferred from the vinyl disc to the platter, but then where does this energy go?); however what we have on this deck as one of the optional upgrades is the platter from the reference turntable. This is machined from highly expensive polycarbonate sheet (Lexan) which is claimed to improve upon acrylic by its ability to dissipate heat as energy more readily .
This provides a more inert platform for the record, thus the attack and decay profiles are improved. The £352 buys not just the platter from the reference deck but also an improved main bearing to go with it. This has a diamond lapped thrust pad along with a tapered , hardened silver steel shaft to provide an exceptionally fine running clearance.
Part 2 to follow
