markf said:The Bigest learning curve is 'The referance' you must have something to judge the last mod / tweek by.
Graham,
Just for the record , what pre amp are you using now and is this your reference for
evaluating your designs . It would be useful to know what you are actually using as a yardstick
(I often hear you say a 52 beater or a 552 beater but I dont think you use either of these
pre amps in your system)
Linnik said:Hi Graham,
You did something like this then, on stripboard.
Dual railed gain stage looks like a very small thing.
Undoubtedly it will be a real nest of the spark!
Certainly we will need some input caps here to make it stable.
(This can be made much smaller in natural size as this one is wide to be clear)
I am too tired to double check this now..
What's the value for R3?
Oz
chrisallan said:I'm all for upgrading the Air Guitar design to implement other features, but I'm worried that the group buy will get stuck again at the re-design stage and we dont seem to have anyone who has the time to do this.
laverda said:I'm just CADing the circuit so I can save as a pdf and post so pls wait a day or so and all will be reveiled. (For those with an interest)
Graham
Could the CAD file be posted as well? That's the bit I need as a dxf file can be imported into pcb software.Anderzander said:Chris
Graham said he would post a pdf of his circuit. I think it's worth waiting for:
Stephen
chrisallan said:Could the CAD file be posted as well? That's the bit I need as a dxf file can be imported into pcb software.
A pcb type file might be even better, what file endings does it produce?laverda said:I CAD in 'Circuit Maker' not sure if I can export as dxf but will have a jolly try go tomorrow.
Graham
Linnik said:Graham,
Do you mean like Evox SMR?
http://www.evox-rifa.com/europe/cmk_obsolete.htm
Otherwise it seems the available values are quite low.
http://www.jt-capacitor.com.tw/pps.htm
The stripboard photo is revised.
1 K resistor for 2 K (R4F), okay but which value is R3??
Graham, please check that SIGNAL OUT point.
Is it correct that way? I mean, the 10 uF cap is
not really a coupling cap there now.
Should it be from the upmost strip?
Which type of transistors have you used?
Well, I am not an expert here but this seems to have very rare 0V outlets..
Will this affect the signal path?? Is the +/- assembly making the 0V
paths so much less important?
Oz
S-Man said:Hi Graham,
Please could you provide an explanation of how the BSSR enhancements work.
R7 and R8 appear to reduce the gain of Q5. Why?
What does R10 do?
