ToTo Man
the band not the dog
My dad's slowly coming to the realisation that he's going to have to mount my 50" Panny plasma on my wall or else it's going to remain cluttering up the hallway indefinitely. (We removed it from my room when I was rearranging my hifi and I'm refusing to allow it back in unless it's wall-mounted above my speakers so that it doesn't spoil my imaging!)
I've had a look at tall TV stands but I'm struggling to find one that's tall enough (I need the bottom of the TV no less than 110cm above the floor). Also, they're not the prettiest of things to look at, and my dad is concerned about their strength/safety. He's also concerned about the safety of hanging the 23kg TV on my wall, particularly because said wall has a chimney behind it (the wall is plastered and wallpapered but has a slightly hollow sound when you knuckle it, unlike my other three walls which are plaster over solid brick).
We'd appreciate advice on how to go about mounting a TV bracket onto a wall like this? The parts/tools required and precautions we should take?
I've watched two videos on YouTube showing a TV bracket being mounted onto an exposed brick fireplace. In the first video the installer drills into the bricks, but in the other video the installer drills into the mortar line and says "you don't want to be drilling into bricks"! As my wall is plastered and papered we're effectively going to be drilling blind.
Also, given that the TV is going to end up pretty high on the wall, it probably makes sense to use a bracket that allows the screen to be tilted down a few degrees. However I'm concerned that this will result in the TV sitting further away from the wall than if on non-tilting bracket. I also have my concerns about whether a tilting bracket is subject to more strain so would appreciate advice on this too.
Cheers!
Cheers!
