Anyone can write and submit a patent. The product doesn't have to work as claimed to be granted, it just has to pass through the process without its function being disproved. There's loads of bullshit patents for meaningless products using invented science.
I hope it's OK to link to other forums... 'cos I reckon ilimzn is spot-on with his understanding and explanation for why mains cables and interconnects affect the sound.
I wish I had been able to assemble my thoughts on the subject as well as he has:
http://www.diyaudio.com/forums/solid-state/324413-dozens-schemes-wire-amp-5.html
And in particular I think the textAIUI his theory is that changing one mains cable for another alters the hum/buzz level/details emerging and being sent out to the loudspeaker. That then makes an audible difference.
It would be interesting, indeed.However his theory is quite testable because we can measure the details of the hum/buzz at the power amp output terminals and see if any changes occur when te mains cable is changed. Then also see if this correlates with people saying (or not) that the result sounds different.
So has anyone done this?
Yes, looked at this way, you can say that the last metre of wire on two components, as you put it, could be forming the twin legs of a ground loop. Unusually for a cables thread, this discussion has actually taken an interesting turn, and I actually feel I have learnt something new about how grounding issues and connections could be making a difference (without invoking quantum theory!) Thanks everyone.Some good points Jim & John.
Many people have expressed the view " how can the last metre of wire make any difference when the power has been transmitted for miles down lots of cables". Hopefully they can now see that only considering the supply impedance is mostly missing the point!
<moderating>
Jez, please stop with the cyclic trolling. You do not speak for “engineers” any more than I speak for the world of computing or whatever. The simple fact is many highly successful audio designers who have a lengthy list of respected products behind them simply do not agree with you. Whatever grandiosity you may ascribe to it I’m sorry to have to point out that yours is but one opinion among a great many. The arrogance with which you continue to below it wins you few friends here and will result in moderation if you don’t tone it down a good bit. I am becoming increasingly sick of the cyclic nature of this argument. It is impacting the smooth running of the forum IMHO.
Omg. Ark less is spot on. You have audiophile fantasy from people who are totally ignorant of electrical and electronic engineering V people who are trained, educated and experienced in the subject.
And yet there are other engineers e.g. Jim, John and the ilimzm (on DIYAUDIO) who do suggest there may be reasons why mains cables can affect the signal integrity. Maybe you need to read the last few posts?
Arkless does appear to be a decent engineer, but his (repeatedly ranty) view on this topic is most likely too simplistic.
Proper psu design is.
..... But of course those imperfections are dealt with by a mains lead..........No PSU is perfect and even then you still have to connect the PSU to the load and decoupling in the most appropriate way. Then you have to connect the thing containing a PSU to other things containing PSUs...
Yes, it is quite difficult to see many situations where changing one mains lead (keeping it plugged into the same socket) can have a significant effect. It's easier to see how swapping a poor interconnect cable (e.g. with screening having excessive resistance) might transfer less mains noise into a low level signal now that we regularly have very high dynamic range sources.Hmm so, AIUI, any normal ie unbalanced system that consists of several components hooked up to an amp will/can have particular earthing arrangements that can compromise the isolation from mains-born interference. What I don't understand is how only one special mains lead to power just one of these components can improve the whole system ie isn't the compromised earthing arrangement still undoing the 'benefits' from the new mains lead via the other paths to the mains?
You seem to have jumped into this discussion rather aggressively. I tend to agree with you that fancy mains cables are generally ineffective and are more about marketing and profit than anything else. But I am interested in the considerable volume of anecdotal evidence that quite a few people do hear differences between different mains cables, and I think it is a bit lazy simply to attribute that all to placebo effects. I therefore am open to suggestion that where amplifier design is less than perfect, swapping a cable with one with slightly different electrical characteristics might make a difference. But that is not to say that I am in anyway promoting or encouraging the purchase of expensive cables, and I agree that the real solution to any mains problem is better design in the first place...... But of course those imperfections are dealt with by a mains lead..........
can you go into a specific example of a psu imperfection and how it is corrected by a mains lead?
